Alternator whine
Old Jul 27, 2009 | 09:13 AM
robbie524's Avatar
Alternator whine
I have a JVC KW-790 indash head unit in a 2006 2.4L HHR LT.. How do i get the alternator whine out of it?? Is this a common problem in the HHR??
Old Jul 27, 2009 | 04:23 PM
Dremin2flyhi's Avatar
Double check all grounding.. Just for a test find a bare metal spot on the chassis or the bolt near the fuse panel under the center console --touch a wire from there to the body of the HU --see if the whine goes away... If it does you can just add that wire --if not--could possibly have a bad HU .
If you have a Digital VOM --- measure in the ohm mode from the chassis to the body of the head unit-- should be less than 1 ohm.. You can also use the DC volt setting and test from the harness ground to the bolt/chassis ground while the unit is on and can hear the whine.. This should measure less than .250 Vdc or 250 millivolts... If not-- then you do have a grounding issue.
Old Jul 29, 2009 | 08:59 AM
hugheshhr's Avatar
I have the same problem with mine. I have an Alpine cda-9887. It was first grounded thru the factory harness. Then I grounded it directly to the amps ground, still have noise. The amp is grounded to the factory point in the hatch. Ive had 2 seperate radios and both had issues.
Old Jul 30, 2009 | 03:15 PM
Navyflyer11's Avatar
I have this problem too. I have tried everything and can't get rid of it.
I think it is a long standing problem.
Bushmaster11B
Drivetrain (Excluding Engine)
Oct 4, 2012 06:38 PM
chadlogan112
Jul 2, 2012 10:52 AM
Dartmech
Dec 23, 2011 04:54 PM
Chris-HHR
Oct 1, 2008 09:18 PM
mende
Sep 23, 2008 12:34 PM
