Horrible Alternator Whine?
Ever since I ran a 4ch amp for my stereo, I've had horrible whine out of my speakers. My amps are mounted right about spare tire in the tray. I've grounded the headunit straight to body, ran two grounds for amp, grounded rca's on both the headunit and amp. I ran a extra rca over my seats and unplugged it from radio and had the whine, so I know it's from the rear. Anyone else ran across the problem? Is it cause my amps are so close to battery and the vehicle's main power wire? Would hate to relocate my amps where they're visible. Any help is appreciated.
Equip:
Digital Designs C5b
Massive Audio Ck5 6.5 Components
Equip:
Digital Designs C5b
Okay, if you have filtered power then I suppose you could have interference to a signal wire rather than a power line. It is possible for the power line to induce a line noise in a nearby coil. Perhaps you may have to experiment with amp and signal wire placement.
There could be many many reasons inwhich you have alt whine. It could very well just be a bad amp or HU. You could have a speaker that is slightly grounding out.
My amp is in the storage bin location on the passanger side and wired directly to the battery and the battery ground. I am using the factory HU and a simple LOC to convert the factory signal to RCA's for my amp. I have replaced my front components but am still using the factory speaker wires. I have ZERO noise in my system and I use non of the anti noise devices that you have NONE.
I would try swapping out the amp and see if it is still there. If you can try the HU as well. Just do one item at a time until you find the bad component.
First off does alternator whine increase with volume? Next explain full detail how all power wire and interconnects are run
Then ill reply with various test find your issue
Dont use ground loop isolators please thats a fix for ****ty installations.....
3 sets of RCA's ran under drivers dash and down the side.
Power wire is connected to pos batt terminal then ran around spare tire into a distrub block and to both amps above.
Ground wire from each amp ran around spare tire and to stock battery ground point on body. Extra ground ran from that point to bolt of seat latch.
All ground points are to bare metal, no paint.
Seat bolt area horrible ground fyi......take notice of factory grounds..
Do rca and any power cables run together. If they cross have them cross at 90degree
Does alt whine increase with volume or steady. So i know which test try
