Another XM Question
Old Dec 10, 2007 | 12:18 AM
JayKWills's Avatar
if you look in my pictures the one with Tugger behind the wheel you can see it
Old Dec 10, 2007 | 12:30 AM
shaginwgn's Avatar
Am/fm antenna is in front, xm is in the back it is about 1.5 inch black box on the roof above the rear window washer nozzle. Hard to see on black hhr but found pic in member's gallery
Old Dec 10, 2007 | 12:39 AM
XM w/ OnStar antenna...........On blue, so it's a bit easier to see!
Old Dec 10, 2007 | 02:13 AM
Dan's HHR's Avatar
Originally Posted by JohnnyLu
Hi All, I am new to the group. My name is Johnny, and I am a proud owner of a 2006 Chevy HHR. Johnny Lubeck
to the forum Johnny
Old Dec 10, 2007 | 10:26 AM
afs9's Avatar
OK, this makes sense now--My sister's Tahoe has that little "fin" on the back.
So it seems that I have the capability for it, but need everything else to get it to work.
I'm wondering now if I was supposed to have it free for 3 months, that it should have had the little box already...time to call my dealer!
Thanks all for your help!
Old Dec 11, 2007 | 07:43 PM
Sparky's Avatar
I have a 08 HHR with OnStar. Apparently the OnStar comes through the front radio antenna. I do not have XM, but I have the antenna base on the rear of the roof, but no antenna.
Old Dec 11, 2007 | 07:59 PM
itschaboykenny's Avatar
I forgot did you purchase new? if so look for this on your window sticker. see below it is right above the government safety ratings (yours might be in a diffrent spot depends on how many options you have)
or you can also check your door jamb sticker for these codes:
UE1 = On*Star
U2K = XM Satellite Radio
Old Dec 11, 2007 | 08:21 PM
nss79's Avatar
I have an 06 with Onstar no XM and I have the small "fin" antenna on the back like JX3. I think they just make the antenna operate both when you have both so you don't have 3 on your car.
Old Dec 17, 2007 | 12:51 PM
dfridge's Avatar
it is Xm ready but does not have the Xm tuner installed You can get it at your chevy dealer parts dept. should be part # 17800594 XM radio you can also buy on line at gmpartsdirect.com for $190.25 + shipping. Go to accessories and type in your vehicle.It will give you a list part should be at the bottom of the list. Your local dealer should give the same price. The antenna is the Factory one [requires holes to be driiled in the roof. see my post at XM radio solution for all.
Old Dec 17, 2007 | 02:11 PM
the_shmoo's Avatar
If the radio is XM ready is the wiring harness already installed in the vehicle or must that be purchased also? I realize that the antenna must be installed. Would appreciate some detailed feedback.
Thanx Keith
betterof2evils4
Apr 3, 2017 08:34 AM
FargoFlash
Jul 12, 2011 04:54 PM
