back seat amp?
back seat amp?
just curios if anybody has removed the rear seats in there HHR and if soo is there enough room underneath that back seat to shove a amp under there and put the seat on top of it?
Do you have the premium sound with the factory sub woofer? If you don't there is a tailor made spot in the left rear quarter where the factory sub and amp go. It should be nothing but empty space if you don't have that option.
I'm away from my office computer right now, but I'll try and PM you a PDF of the section of the shop manual you'll need. Should be able to get that to you tomorrow afternoon when I'm back in Charlotte if that works. Maybe somebody here can link you up before then.
There is plenty of room under the rear seat. You don't have to take it out. Just remove the plastic thing with two storage compartments that is directly behind it. This allows access to under the seat. Also the rear wall of where the tire is next to the battery. Just unsnap the plastic piece where the bottom of the rear gate would shut to gain better access for installation.
