BAFX ODB 2 question
Old 10-30-2018, 11:21 AM
Cat Man HHR's Avatar
BAFX ODB 2 question
Hi
Does anybody know of a app for this product that shows the charging system? I don't care if it's just battery voltage.
I have the app Torque(lite) and it doesn't show any parameters at all. It is the free version. That could be the reason also.
Thanks
Cat Man HHR is offline
Old 10-30-2018, 12:38 PM
I have the Torque Lite app on 1 phone. There are numerous things it will monitor. You just need to scroll through the list and find one that monitors voltage.
On the home page, click the "cog" wheel (lower left) to open the menu. Then click on Add display.
firemangeorge is online now
Old 10-30-2018, 12:50 PM
Cat Man. Your's is a 2010 SS ? If so, it's got the RPD which has a screen that shows the voltage. Just switch to that display.
Old 10-30-2018, 12:54 PM
George look through that thing and didn't see it. If it's there it's must be small.
Yes it is a 2010 SS.
Old 10-30-2018, 12:57 PM
I hit the gear icon but not knowing this app have seen Add Display but never navigated thru it. I'll go back and look again.
Old 10-30-2018, 01:33 PM
Other settings>manage available OBD2 PIDs>ignition 1 voltage
donbrew is offline
Old 10-30-2018, 01:34 PM
OK found what George was explaining.
Selected dial and now show ECM voltage as a gauge face.
I do have a couple of screens behind it that I can't see how to get rid of. One is like a 4 gauge dashboard and the other is a graph for acceleration.
Old 10-30-2018, 01:58 PM
If you are still looking at Torque, long press > delete on dialog.
I see 3 different voltages that all should read the same; ign 1, control module and obd adapter.
donbrew is offline
Old 10-30-2018, 02:04 PM
Don you lost me on that.
Are you saying what I had added. Is how I delete it?
I'm in my house and using my PC to write this. Really don't know any way else.
Old 10-30-2018, 02:18 PM
The RPD screen: Push the knob. Then turn till the side screen shows the barometer, outside temp, battery voltage.
Quick Reply: BAFX ODB 2 question
