Can I use the fusebox empty slots for other things?
Old Mar 26, 2014 | 03:30 PM
hhrumadbruh's Avatar
I'm just wondering if I can tap into the fuse box and slap a fuse in an empty slot and then run a wire on the other side to power a line driver or something.
Old Mar 26, 2014 | 04:10 PM
I don't know for sure, but .. you would have to take the halves apart to do the splicing anyway that would be the way to check. I am guessing that the hot side of all the connections is indeed hot, just no wire on the other side.
Old Mar 26, 2014 | 09:06 PM
Lucky's Avatar
It should be just find to do that. Anything in the fuse box that has battery power that's not switched on and off with the key should come from the main battery cable connection.
Just make sure you use the correct fuse size for what ever your powering
foolmoon_design
Mods - Engine/Exhaust
18
Aug 30, 2014 01:06 AM
jimpennjr
10
May 31, 2011 08:24 PM
urbexHHR
Mar 17, 2010 08:31 AM
IMPALADAKID
Dec 1, 2009 08:28 PM
SindyDix
Aug 10, 2006 12:58 PM
