Cutting the back of the radio area to increase depth
Old Oct 3, 2012 | 08:09 PM
07azhhr's Avatar
Just wondering if any of you that have installed aftermarket head units have cut out part of the back of the radio opening to fit your hu flush. I am about to do this as the Pioneer DEH-80prs hu is the same depth as the factory radio opening. With the center air ducts attached to it it leaves just enough room to cut out for the rca's to fit so the hu can sit flush. I won't be doing this until Mon or Tues but I will take pics for anyone else that might find the need to do this.
If any one has pics of this already please feel free to post them.
Old Oct 3, 2012 | 09:05 PM
Eric B's Avatar
I don't have pics. But I had to cut mine.
Old Oct 3, 2012 | 09:21 PM
American & Proud's Avatar
Rest In Peace
Cut mine out as well.
I used an air body saw made Quick easy work of it.
Old Oct 3, 2012 | 10:08 PM
07azhhr's Avatar
Don't have my air saw anymore so I will have to use my dremel. I dont think I will need to cut all that much out so I should be ok. But this things battery doesn't last long thru the semi thick plastic use in these cars. Well atleast it did not for my a-pillars. I had to switch to my angle grinder for that but it will not fit very well into that radio opening lol.
Old Oct 3, 2012 | 10:23 PM
Rest In Peace
Mines a name brand one from my bodyman days.
You can get one from Harbor Freight currently on sale for $19.99. 5 pack of blades fine or coarse are $7.99.
I have all the other type tools you mention and the air saw seemed to be the best easiest choice as it's straight and had good reach to cut it out like a red hot knife through warm butter.
Give your other tools a try but keep the air saw in mind, at 20 bucks it's cheap enough and you'll use it on other projects.
They even sell an electric body saw for $32.99 (not currently on sale) for those that are compressor challanged.
Old Oct 4, 2012 | 03:34 AM
07azhhr's Avatar
Mine was a Ingersol Rand as were all my air tools but that was then lol and this is now where I am airless. If it weren't for the battery draining quickly, the dremel would cut thru it in a matter of minutes but literally it drains in a few less minutes then needed most of the time. And it is an actual Dremel brand dremel . I might run over to HF and get there little plug in dremel that they have on sale right now and use that to be honest. IIRC it is on sale for $7.99 and I have a tube of blades.
Old Oct 4, 2012 | 08:04 AM
Chozen317's Avatar
I thru several tools at it. There is a pic in my build log. I just finished the audio build last night. I hope to update the build log when I get home from my sons football game tonight.
Old Oct 4, 2012 | 04:11 PM
07azhhr's Avatar
Thats the same dremel I have which is why I want to get a little electric one as they are short enough to fit in there as well as being able to last long enough to complete the job in the first go at it :).
Old Oct 4, 2012 | 05:53 PM
Chozen317's Avatar
I couldn't get a good angle with the dremel. My hand saw did most of the work.
Old Oct 5, 2012 | 01:51 AM
prod's Avatar
So what are you guys doing with the air duct, just let it hang loose?
