Head unit install troubleshooting
Old Jan 14, 2014 | 04:00 PM
MurderMittenSS's Avatar
So I installed a Sony XAV-601BT the other day. Huge improvement over stock the stock radio. I used the GMOS LAN04 harness for the install, I purchased it used from somebody on the Cobalt forums. I also used the Axxess ASWC-1 for to retain the steering wheel controls.
What I'm running into is no more sound from the driver rear speaker, and for the life of me I cannot get the steering wheel controls to program properly. I soldered all connections to ensure nothing comes loose, and I've double checked all speaker connections to make sure they are correct. I have sound from the drivers rear speaker when the stock radio is connected, I verified that just a few minutes ago.
The steering wheel controls are really throwing me off. I followed the programing procedure, and the only button thats doing anything is the volume up, which tries to connect to onstar. I'm thinking maybe I tapped the wrong signal wire for the controls? Any insight would be great guys.
Old Jan 15, 2014 | 01:58 PM
oldracer's Avatar
Well according to Crutchfield, if you did not have the premium sound system, these will not work? You did not mention which stereo unit was in the car so I would suggest a visit to a shop and/or getting the wire diagrams for both adapters to make sure you do have it wired correctly.
Britjoe
Nov 28, 2014 02:02 AM
Xandict
May 28, 2013 12:56 PM
Shanes0406
Aug 13, 2012 07:56 PM
steveo3140
Jun 30, 2012 09:51 AM
