Help!!!!!!!!!!!!!!!
Old Aug 28, 2006 | 03:37 PM
TX-HHR's Avatar
I had the exact same problem. I was using the spare key and had the same type of start up problems after installing an amp. I think the car remembers the last key that was used to start it, somehow.... Glad it's back working
Old Aug 28, 2006 | 04:33 PM
nfboy's Avatar
Originally Posted by mudbilly
I talked to the dealer service department today. They don't have a clue as to why my original key doesn't work since I disconnected the battery. I can't remember if I had the key in the ignition or not when I disconnected it........ all my chimes don't work with the new HU...........but maybe some kinda power spike confused the key memory
I'm afraid to try it again, cause then maybe my second key won't work either..
They will re-program it when I go in for my first oil change
but it just doesn't make any sense to me, what am I supposed to do if the battery dies on a trip, I have to replace it, and I don't have the spare key with me .............
So your original key still won't work? That is a different experince than I had. Once I got mine started with the spare key, regular key worked just fine.
Old Aug 29, 2006 | 08:34 AM
mudbilly's Avatar
actually, i tried the original key again the next morning and it didn't work, then i tried the spare immediatly after and it seemd to take longer than usual to start cranking........but then it started
now i'm afraid that something will happen such that the spare key won't work either, i'm waiting until i get to the dealership to try the first key again..
