hhr 2007 head replacement need help!!!
Old Jun 30, 2013 | 07:50 AM
billynad's Avatar
allo I own a chevy hhr Lt 2007
2.4 litre lt
no onstar
steering volume control
factory pioneer audio system with subwoofer and I think theres an pioneer amp to this system!
im buying a pioneer x2500bt head unit with iphone app control im buying the head in a big retail store might install it myself or have somenone else do the job
my concerne is buying the hardware!
tech at store tells me about bypassing the pioneer amp he lost me there
if someone can give me a list of adapters I need I will follow your list at the store to buy hardware! exemple wire harness bypass adapter steering wires parking brake bypass im not to familiar with it so if there any one here go ahead I rather get help from someone here instead of a might know it all tech at retail store!
best regards to all of youguys
thanks
Old Jun 30, 2013 | 09:02 AM
miltonfisher's Avatar
I have the same system in my 2009 SS and door chimes on star and some other features run through the Head Unit or the amp. In my opinion I think I would go to a reputable Audio shop in your area and get a second opinion. I do know you can bypass the factory amp but I know of one cable you really need for that and it runs about 60 dollars, and the unit to keep your steering wheel controls. Check the other post in this forum and you will find that info. Just my opinion but i don't trust the big box stores they more times than not try to sell you more than you need especially if they realize you are not knowledgable. The head unit you are thinking about is sweet and I do believe you can bypass the amp but from what i see it does not have the same power as your factory so you might loose some volume. Please do some research I would hate to see you spend that kind of money and be disappointed. Good luck and keep us posted on how it turns out.
Old Jun 30, 2013 | 09:30 AM
billynad's Avatar
Will do soo thanks
Old Jun 30, 2013 | 12:14 PM
oldracer's Avatar
I installed a Pioneer X950BH unit, while not the same model as yours I suspect the required hardware would be similar as would be the install procedure. I had to but what the shop called an "interface module" and that thing was nearly $100, I needed an antenna adapter since the pioneer unit used the large type of plug and the HHR uses the small one. Once I had those parts the connection went just fine as the module just allowed everything to plug in. I found that the HHR amp and rear speaker works fine with the module and the steering wheel controls also are okay too.
I found I had to cut out the rear plastic portion of the "box" the hear unit sits in as the wires that come out of the Pioneer head unit took too much room. I used a hot knife and it cut easily and is not used for any structural strength.
Old Jul 1, 2013 | 07:15 PM
billynad's Avatar
great explanation mate I found that going on the pacific accessory industry website I have all info by model and make of car
did you buy a adapter for steering control or did it fit right on the interface module
Old Jul 1, 2013 | 07:19 PM
billynad's Avatar
did you buy adapter for steering control or did it fit on interface module
Old Jul 1, 2013 | 10:33 PM
oldracer's Avatar
For GM cars and models such as the HHR they make two interface modules, one for steering wheel controls and on-star and another without their functionality. At the shop I dealt with, the owner knew which one I needed by memory!!!!
Old Jul 2, 2013 | 07:55 AM
jczboy's Avatar
If you are still thinking about doing it your self... You can get all the stuff you need to install it your self at crutchfield.com Sales guys helped me with every thing I needed.
Gas
Aug 24, 2015 06:47 PM
Ikenna155
Apr 14, 2012 05:59 PM
lcombs1950
Aug 24, 2011 08:55 AM
bandit12
Jul 17, 2006 04:15 PM
