2007 hhr new head
2007 hhr new head
I replaced the head got it all timed and when tighten intake to spec i can only turn the engine over 1/4 turn by hand with it loose it turns of easy by hand. Not sure what the issue is now
Welcome to the site
I'm unclear on tighten intake?
If your saying that after you tighten down the head you can't turn over the motor with the plugs out then the pistons are hitting the valves or the head it's self.
I'm guessing maybe you have a remanufactured head and I would be wondering if the head has been milled down too far.
Sounds like an error in timing component alignment. Time for a double check on those timing marks.
Maybe a picture or 2 of how you have it aligned will help us identify any errors you may have made.
Fwiw. From other pictures/posts I've seen, it seems the Ecotec engines can be a little tricky to line up if you haven't done one before.
Good picture in this link, post #4. https://www.chevyhhr.net/forums/how-...-timing-50253/
Notice that the sprockets line up with one exhaust, one intake.
