Installing amps questions
Old Apr 13, 2016 | 09:57 AM
cutlassboy's Avatar
good afternoon everyone. new to this and just bought my 07 hhr. I installed my head unit and now wanna install my amps. whats the best way because im not use to the battery in the trunk? Will I need a bigger battery??
Old Apr 13, 2016 | 11:01 AM
drummerboy0088's Avatar
Should be able to use a GMOS-LAN-03 and be fine.
Amazon.com: Axxess GMOS-LAN-03 LAN OnStar Interface for Non-Amplified Systems: Car Electronics Amazon.com: Axxess GMOS-LAN-03 LAN OnStar Interface for Non-Amplified Systems: Car Electronics
My 1LT which says it had Onstar (even though I don't have the rear view mirror for it) and no XM I used the GMOS-LAN-03. Was able to retain factory chimes, and used the AWSC-1 to retain my steering wheel controls.
Old Apr 13, 2016 | 05:32 PM
I moved this to a new post, from an old 2008 thread.
Welcome to the site!
You will have to determine the voltage and ampere needs of the amps, some have added a second deep cycle battery
Old Apr 14, 2016 | 12:52 AM
prod's Avatar
Modest amps up to 1000w RMS aren't a problem for the original battery, ive been running that for years.
I think the best way is to mount amps in the rear, more space and less run for thick power wires.
PhatBob
Feb 22, 2019 05:07 PM
nacorona
Jul 10, 2011 04:24 AM
OVRBOOST
Feb 4, 2011 08:28 PM
cj krause
Apr 4, 2006 03:34 PM
