Lessons Learned: Using GMLAN adapter with aftermarket radio
Old Feb 16, 2007 | 01:06 PM
BIGJP's Avatar
Gmos-03
I have installed a kenwood head unit with this adapter as well. The only problem I have is when the chimes end there is a real nasty sound that kind of sounds like a short. Has anyone else had this problem?
Old Feb 16, 2007 | 01:53 PM
no issues here
Old Mar 4, 2007 | 02:50 PM
BIGJP's Avatar
Chimes
I want to install a separate speaker for the warning chimes . How do I wire this different on the GMOS 03 adapter so it wont go to the left front speaker at all?
Old Mar 7, 2007 | 11:50 AM
Mach2's Avatar
Do not route your speaker wires from the head unit to the speakers through the box Just connect your external speaker you will use for the chimes to the LF output of the GMLAN box.
Old Mar 14, 2007 | 08:28 PM
BIGJP's Avatar
Do I connect the left front speakers from the head unit to the GM wiring ? If so what colors am I going to use?
John
Old Jun 15, 2008 | 07:41 PM
djmoose's Avatar
So, I have the low end factory stereo...but putting in aftermarket with amps. Do I need the 04 so it routes the onstar audio to the Line level outs to my amplifiers? I won't have any speakers powered by the HU.
Mach2
Aug 30, 2018 04:07 PM
camaro98z28
Jul 28, 2010 09:18 AM
tahenke
May 20, 2010 11:27 PM
Mach2
Jan 27, 2007 06:06 PM
