Need help please i just replace the factory radio for a boss bvcp9675a
Old 12-02-2018, 11:49 AM
Rockdrigo's Avatar
Need help please i just replace the factory radio for a boss bvcp9675a and wont turn on, i just got a aftermarket harness from amazon https://www.amazon.com/dp/B01MUKR33Q/ref=cm_sw_r_cp_apa_XQbbCbJJDBVPV
Can anyone had the same issue, or maybe this harness is not compatible with this new boss radio?
thank you
Rockdrigo is offline
Old 12-02-2018, 12:17 PM
Did you read this?
What did you use for ground?
donbrew is offline
Old 12-02-2018, 12:54 PM
Rockdrigo's Avatar
Originally Posted by donbrew
Did you read this?
i basically connect the harness following the colors that the new radio has, i todd the ground was connected along with the harness. Is there any other harness that i can use with this new radio?
thank you
Old 12-02-2018, 01:36 PM
Not very good reviews on Amazon. What about the highlighted part of donbrew's reply? Did you read and understand it? It's also right at the top of the Amazon listing.
RJ_RS_SS_350 is offline
Old 12-02-2018, 01:47 PM
Rockdrigo's Avatar
thank for the reply, yes i just notice that, this was a gift from my wife and now i may need to find another harness to make this radio working, if you have any recommendation ill apreciate that.
thank you
Old 12-02-2018, 02:00 PM
I have never heard of a installation kit without directions.
Why not just do what it says and run a wire? If you want to retain the chimes and use steering wheel controls you will need other adapters.
What radio are you replacing, the listing says that it does not work with the "premium" system; That is the one with a sub woofer in the back.
donbrew is offline
Old 12-02-2018, 03:02 PM
Rockdrigo's Avatar
Im replacing the factory Radio and my 2009 HHR doesn't have any 8" sub-woofer ins the back side panel, I have the HHR LS Panel without window panels on the rear seat, so I called Crutchfield to recommend me a compatible harness for my HHR (Base panel), since this car doesn't have the pioneer system they told me that this harness will work fine https://www.crutchfield.com/p_120LCL...Interface.html I'll received this new harness by Wed. so I'll let you how this goes.
Thank you for the replies guys.
Old 12-02-2018, 05:58 PM
You beat me to my recommendation, chat Crutchfield, those people are knowledgeable and very nice to deal with.
Oldblue is offline
Old 12-02-2018, 06:55 PM
Rockdrigo's Avatar
thank you Oldblue, it was so frustrating today trying to get this radio conected , now i dont will have music until Wed, but its always good to learn something new.
thank you for everything!
Old 12-02-2018, 09:38 PM
Please, do post a follow up to confirm you got things straightened out.
Oldblue is offline
Quick Reply: Need help please i just replace the factory radio for a boss bvcp9675a
