Original Antenna and radio display dimmer
Old Jan 7, 2012 | 10:09 PM
mudbilly's Avatar
SUCCESS
i found the pink wire in the radio harness that i had cut apart years ago...i hooked up to the powered antenna wire from my head unit and it made a HUGE difference......i can get a station, that before, i had to drive 30 miles toward it to get even poorly............ i wish i knew this this years ago
i would assume that it is 12vdc going to the antenna booster and that the wire in the head unit is just a dry contact that switches a rely to get power to the antenna,,, but i am only guessing at this......??
i also found the grey wire for the display dimmer,,,,, hooked that up to the head unit and Voila............it works like a charm when the headlights are on...
the sony has infinitly adjustable lighting,,,,, so i was able to color match the rest of the dash......
JAMMIN.............
and then there is this from halloween...
elleelle
Aug 5, 2013 05:03 PM
osie59
Jul 19, 2012 02:44 PM
john
Jan 23, 2012 08:09 PM
clobert
Mar 19, 2011 11:01 AM
rsully745
Jan 29, 2011 10:44 AM
