pioneer 5800 install experts in here please
Old Aug 13, 2006 | 10:45 AM
mudbilly's Avatar
OK, I've got the stock HU out and getting ready to install the 5800. I also bought the gizmo that will let me use my steering wheel controls.
I want to use the factory speaker wires (at least until I determine if I am going to put in an amp)
I also would like to keep the radio on until the door opens feature.
I've read as many threads here as I could find, but still can't determine how EXACTLyY to wire this all together.
Laptop sitting next to me at the car hoping for some friendly help.
Old Aug 13, 2006 | 11:40 AM
mudbilly's Avatar
is there a switched +12 wire in the factory harness? or do i have to run a wire to the fuse box per this
https://www.chevyhhr.net/forums/show...?t=1600&page=4
Old Aug 13, 2006 | 12:09 PM
HHR PNOY's Avatar
Here's some wiring info you can use (info found from other postings):
[Harness 1]
Battery(+) = [RED/WHITE]
Ground(-) = [BLACK/WHITE]
Left Front Speaker = [DARK-GREEN(-)] [TAN(+)]
Right Front Speaker = [LIGHT-GREEN(-)] [LIGHT-GREEN/WHITE(+)]
[Harness 2]
Left Rear Speaker = [BROWN(-)] [BROWN/WHITE(+)]
Right Rear Speaker = [TAN(-)] [DARK-BLUE(+)]
You have to tap the ACC wire either in the fuse box or somewhere else. You can also grab accessory at the ignition harness.
Old Aug 13, 2006 | 12:30 PM
mudbilly's Avatar
cool, thanks, any idea about how to route a wire to the fuse box???
i'd much rather stay inside the dash if possible, i thought for sure the cigarette lighter would have been switched....but, nope it is hot all the time
i think all i need is a switched +12v to finish this up and grab a beer
Old Aug 13, 2006 | 02:09 PM
mudbilly's Avatar
well, it's in.................sort of...................i fished a wire to the fuse box and found switched +12, but the radio goes off as soon as i turn off the key
the steering wheel controls don't work, but i think that is because i haven't programmed them yet...................my brain hurts too much to get into that right now........................
AND
at first listen, i believe that i'm gonna have to amp everything in order to get the sound i want..............
so/ i'll be riping it back apart...............
time to go for a cruise down to the local watering hole and see, errrrrrr listen to how it sounds ,
BEER THIRTY
Old Aug 13, 2006 | 11:34 PM
ng8650's Avatar
If you want the radio to stay on until the door is open then you have to tap into fuse #21 on the center console. That's what I used, with an add-a-fuse, and it works great. I have my head unit, Sirius satellite receiver, and PAC steering wheel adapter all hooked up to fuse #21. Everything stays on until I remove the key and open the drivers side door.
Ng
Old Aug 13, 2006 | 11:40 PM
HHR PNOY's Avatar
follow the red wire leading to a black connector (look at the left of the pic). That's fuse #21 connected via add-a-circuit fuse holder.
The add-a-circuit looks like this:
http://www.partsexpress.com/pe/showd...number=071-585
You can get it at a local car parts store like pep boys or autozone.
Old Aug 14, 2006 | 12:14 AM
ng8650's Avatar
Nice pic/post PNOY. Keep it handy as it is a hot item for new HHR owners
Ng
Old Aug 14, 2006 | 06:50 AM
mudbilly's Avatar
where is that fuse panel located?? i was wondering why my under hood fuse panel did not look like the pic you posted in the other thread i was using..........i just assumed that our fuse panels looked different
Old Aug 14, 2006 | 06:54 AM
captain howdy's Avatar
The center console on the passenger side.
