Problem with new HU and LAN-03
Old Aug 18, 2008 | 03:39 PM
BigBeefer's Avatar
I just installed a Sony head unit, using the LAN-03 adapter, both from Crutchfield. Everything is wired up and everything works. The problem is I have no running lights or accessory lights(the green lights on the HVAC controls and door locks). Brake lights, blinkers, headlights all work normal. The funny thing is that the running light fuse, a 10A, pops almost instantly when I turn on the running lights, leading me to think there is a short or ground issue. I grounded the HU to the factory wiring ground. I ripped everything out and reinstalled the factory HU and everything works again as normal.
Anybody have ideas? Could the LAN-03 box be bad?
Old Aug 18, 2008 | 03:50 PM
Could be, I know I had a harness go bad and it had to be replaced.
Old Aug 18, 2008 | 08:33 PM
stuns's Avatar
When I bought my LAN adapter I was told 1 in 3 would be bad. That if I was to fet one that worked on the first try I was lucky.
Old Aug 19, 2008 | 07:36 AM
BigBeefer's Avatar
Great... Name:  banghead.gif
Looks like I will have to call up Crutchfield and cry like a little girl Name:  bawl.gif
Old Aug 19, 2008 | 09:31 AM
stuns's Avatar
However I found some alternatives. If you want to retain your chimes but do not have a nav unit there is the GMRC-lan-03. If you don't want the chimes then there is a less expensive alternative. XSVI-2104 and the XSVI-2104NAV. The latter for Nav units and the former for non Nav. Hope this helps!?
Old Aug 23, 2008 | 12:43 PM
BigBeefer's Avatar
Well I just got off the horn with Crutchfield. After a hour of wire verification, the Crutchfield guy is unsure what the issue is. All my wiring is correct.
They are sending me another LAN-03 kit, should get it this week. I will update on if that fixes the issue or not.
Old Aug 23, 2008 | 01:01 PM
stuns's Avatar
Glad to hear they are sending you out a new one without too much fuss.
Old Aug 30, 2008 | 11:56 PM
BigBeefer's Avatar
Well I finally received the replacement unit this week and got it installed today. All works as it should. No fuse popping, all parking lights work normally. Now I just have to send the bad one back and get my credit for it.
I'm happy its working and all, but I still am very disappointed at the lack of QA on these parts. For a simple circuit board with some IC's on it, there is no reason they should charge $130 for it and for it not to be perfect. Its not a complex piece. The lack of quality of the board itself was apparent as well, my new one had a bent component on it.
Kinda sucks the entire electronic world is made overseas, they could at least make sure their crap works.
urbexHHR
Nov 3, 2010 07:00 AM
06gray2ltHHR
2.4L Performance Tech
Aug 1, 2009 10:45 PM
ts5p
Oct 6, 2008 02:47 PM
suburbanjunior
Apr 1, 2008 01:12 PM
Black Rose
Dec 7, 2007 11:28 AM
