Radio fitment
Old May 16, 2026 | 03:49 PM
Bob-K's Avatar
Radio fitment
Is a stock radio from any year HHR a direct swap into a 2006 HHR?
Old May 16, 2026 | 04:30 PM
Physically, yes. But computer matching needs to be done, that takes a bit of know how and the correct computer.
Old May 16, 2026 | 04:52 PM
You will have to have the vin from the donor car .
Old May 16, 2026 | 05:18 PM
Bob-K's Avatar
Thanks for the quick replies.
Are they all computer matched, or just certain years?
Old May 16, 2026 | 09:04 PM
All.
A brand new, never used radio does not need it. Some used radios have had the chip disabled so they don't need it. If you know what you are doing you can reprogram the chip in the radio or remove it.
The security works by the BCM interrogates the chip, if it is blank the BCM inserts the VIN if it does not match the radio is disabled. If there is bno chip the radio will function.
Old May 17, 2026 | 07:33 AM
Just wanted to confirm why you think it’s the radio head unit , the door speakers are known to fail
Old May 17, 2026 | 08:15 AM
If you are trying to add BlueTooth the answer is no. Bluetooth lives in the OnStar Module.
Old May 17, 2026 | 08:51 AM
Bob-K's Avatar
I never said it was the head unit. The CD player quit working.
I do have an intermittent problem with a very loud pop coming from the speakers if the radio is left on the on position, but that's not the reason for my post.
I'd like to have the CD player working again.
Old May 17, 2026 | 09:08 AM
What is a CD?
Old May 17, 2026 | 09:14 AM
I didn’t see anything about the problem, the pop noise tells me the speakers are faulty.
as for the cd player it it usually the drive belt has broken.
pdmorris1
Jan 12, 2015 05:55 PM
Aholland06
May 18, 2013 03:14 AM
mcgaugh
Nov 16, 2010 08:10 PM
fantomfreke
Feb 8, 2007 11:44 AM
