Replacing stock subwoofer
Old May 8, 2012 | 12:47 PM
Pyzik's Avatar
I have the rear end torn out and the stock sub unscrewed but the sub doesn't want to come out. Any help?
Nevermind, gotta take it all the way out...
Old May 8, 2012 | 02:20 PM
barfan1's Avatar
There is actually a bolt that goes right into the magnet on the back of the stock sub, you need to take the stock box out of the car. It is a PITA!
Old May 24, 2012 | 09:35 AM
bad03xtreme's Avatar
Has anyone had any issues with their amps getting hot being mounted under the back? I had mine hooked up and it was working fine and I went on my first trip more than 30 min and after being in the car for about 2.5 hours the sub started really hitting and the bass was much more noticeable.
I know subs and amps have a break in period and these had been in for about 3 days total. The amp was pretty warm but not too hot to where I couldn't touch it so do you think it needs to be adjusted again or is it getting to hot?
Old May 24, 2012 | 09:57 AM
chefhhr's Avatar
Amps get hot, especially when they are ran non-stop for a long period of time. I wouldn't get too concerned with a warm amp after running hard for 2.5 hours. I used to have a small Kenwood amp years ago that I could literally fry an egg on it was get so hot! It actually would cut out after producing my bump for 20-30 minutes. It would turn back on once it cooled down.
Old May 24, 2012 | 11:11 AM
Can you think of a reason the sub would start producing more sound? Do you think it was a result of the heat or is it just a result of the amp and sub getting use for the first time and becoming "broken in"?
ChevyHighPerformance
Dec 24, 2012 09:15 AM
Pretzel
Apr 7, 2011 07:47 PM
