Right Tweeter Problem
Old Jun 30, 2018 | 09:43 AM
DWBlair's Avatar
Tried searching the forums and have seen similar, but not quite the same problem. The right tweeter on my 2010 only partially works. Low volume and tinny sound like a blown speaker. Swapped with new factory replacement speaker and it does the same thing. Swapped it with the left tweeter (which works fine) and it does the same thing. Would this be a wiring issue or a head unit (standard factory unit) issue?
Old Jun 30, 2018 | 10:28 AM
The tweeter are wired directly to the door speaker. So if the door speaker is working it is a wire between them.
Unless you are calling the door speaker a tweeter. The tweeters are on the windshield trim.
I think the crossover network is built in to either the speakers or the head unit. The diagrams don't show it at all.
Old Jul 5, 2018 | 08:27 PM
DWBlair's Avatar
Thanks for that info. That info of the the tweeter being directly tied to the door speaker led me in the right direction. I took out the door speaker and found the problem. A while back, I had to have the passenger side front window replaced. When they replaced it, they knocked the ground wire off the door speaker.
Old Jul 6, 2018 | 07:35 PM
Good news it wasn’t more expensive, with new speakers and well then a new HU and amp, which leads to new sub woofers and touch screens, an X box ........
dfornet
Aug 10, 2014 08:19 PM
Shanes0406
Aug 2, 2012 06:06 PM
Dieselracer
Oct 19, 2011 01:42 AM
jgschroeder99
Mar 17, 2010 08:43 AM
tahenke
Sep 22, 2009 02:02 PM
