Single LED light
I have mounted a Varad LED light and used the IGN harness (yellow wire) and hooked the constant 12V to the positive post on the fuse box, and grounded on the strut tower bolt. Simple enough but when I try to remote start the stock alarm activates and the horn blows then the car shuts itself off. Also there is a nasty click when Ignition is turned off. Can anyone help me??
Thanks No its just a single LED for theft deterrent. |
Like a single LED or a strip?
If you used the ignition harness its the brown wire.I asked yesterday and hooked up my remote wire for my amp with no problems.
Where did u mount it and what is it for
Would the brown wire be used as a ignition grounded when engine is off?
What kind of capacitor??
| All times are GMT -5. The time now is 03:29 AM. |
