Steering Wheel Audio Controls Won't Work
Old Dec 30, 2017 | 07:28 PM
Bill Burke's Avatar
I wanted a new head unit with phone and rear veiw camera. So I bought a Pioneer avh 291BT, then a GMOS-LAN- 04, And finally A ASWC-1. Wired them all up and the radio works, the rear view works, But I can't get the steering wheel controls to work. I called there tech support for Axxess They finally said I had a bad ASWC-1 so I sent that one back and got a new one. Same story. So I am wondering if anyone here has some ideas what could be wrong? Please help if you can. I am new to posting here and say thanks in advance. Bill B
Old Dec 30, 2017 | 07:38 PM
Welcome to the site, it could be a second bad part, possibly.
But check your wires it could be a loose connection
Old Dec 30, 2017 | 08:16 PM
Welcome to the forum.
According to the Crutfield site from what I can see quickly is the GMOS-LAN-04 is the wrong one - and should be the GMOS-LAN-03: https://www.crutchfield.ca/p_120OSLA....html?tp=74040
And the ASWC-1 is flagged as the wrong one, and should be: the PAC SWI-CP2 https://www.crutchfield.ca/p_541SWIC....html?tp=73922
Old Dec 30, 2017 | 10:29 PM
Bill Burke's Avatar
I got my info from Amazon, So I am sending that ASWC-1 back to them and ordered the one from crutchfield. The other I is the correct one according to crutchfield. It is probably because I forgot to ut inthe first post that My car has the factory installed Pioneer amp that it calls for the -4 instead of the -3. Thanks for the quick answers. I Will post the results when I get the PAC SWI-CP2 . Bill B
Old Dec 30, 2017 | 11:00 PM
Good deal. Sounds like you are on the right track.
Old Jan 7, 2018 | 07:02 PM
Bill Burke's Avatar
Spent a couple hours out there installing the PAC SWI-CP2 And a funny thing happened It works just like it should. Thanks For pointing me in the right direction. Bill B
Old Jan 7, 2018 | 08:05 PM
Cool. Enjoy.
Old Jan 8, 2018 | 08:16 AM
It’s Monday, sound give that volume button a workout!!
Let’s CRANK it UP!!!!
https://www.chevyhhr.net/forums/cran...er-ends-55045/
bsarte
Dec 7, 2010 06:36 PM
adamlowery
Apr 4, 2006 08:21 AM
