Stock Radio Pinouts
Seems that you have two choices. The pink wire #8 on the radio harness will trigger the amp when the radio goes on, which some say will happen with door chimes, which you may not want.
Or you could just run from the fuse block using an add-a-fuse connector to one of several accessory circuits. That would mean no trigger on the door chimes, but also no delay power off feature, which I would want.
Im trying to find out myself, and havent tried either yet. Have a thread here:
https://www.chevyhhr.net/forums/audio-video-17/where-catch-pink-remote-wire-19890/
Fuse box is the best choice I think. Use an add-a-circuit adapter in one of several spots that are controlled by the retained accessory power system. #21 is empty I think, sunroof, window would also work.
