trying the find the right wire hardness
Old May 12, 2015 | 04:05 PM
Alejandro014's Avatar
Hey guys I'm wanting to put in a pioneer double din but having trouble finding the right stereo harness. I have the 07 hhr Lt with the 7 speakers without on star I believe. I spoke to someone from sonicelectronic and told me i needed this one. http://www.sonicelectronix.com/item_15123_Scosche-GM13SR.html
Old May 12, 2015 | 05:27 PM
First, Welcome!
Second, I moved this to the AV forum
Third, I got no idea what "wire hardness" is. Do you mean "harness"? If that is it, then it depends on what you are trying to do. I suspect that the manufacturer would know more about it than I.
Old May 13, 2015 | 07:03 AM
Welcome to the site! Then that would be the harness you need, if that's what the seller is telling you!
Old May 13, 2015 | 09:54 AM
jczboy's Avatar
You will need that or something equivalent so your chime module will still work. You will need other things, if you have and want the steering wheel controls to still work.
Peace
Old May 15, 2015 | 02:49 PM
oldracer's Avatar
You did not say which Pioneer unit you want to use but as an example I used a Pioneer X950BH which has been great so far. I have a post on here that I mention how I did it if I remember? I bought mine from a shop called Car Audio 1 in Imperial Beach CA, a tad far from you but you could call them at 1-619-628-2400 and ask them what adapters you'll need. I have no idea what the model numbers of the various boxes were but the car never knew I switched head units. I had to buy several, one to do the main connection to the lan, one for the steering wheel controls, one for adapting the antenna and one for the backup camera. There are wires that have to be connected and I would solder them and use heat shrink tubing. You'll have to cut out the back of the plastic area where the unit sits in and also do what is called "the bypass" so you can watch videos anytime. There is a good forum for these units named AVIC411.COM which covers the Pioneer units well.
I have a 1TB solid state hard disk hooked into the USB connection and it sits in the glove box with about 10,000 or so MP3 songs and a bunch of music videos.
aquabill
Mods - Engine/Exhaust
Jul 11, 2013 04:49 PM
lefthandedrighty
Dec 23, 2012 08:43 AM
gucci
Tires & Wheels
17
Dec 18, 2011 05:51 PM
DrTrapper
Oct 7, 2011 08:40 PM
Putter
Jan 3, 2011 12:20 PM
