Need a Tach wire
Need a Tach wire
Hi, I'm changing over to CNG and need a tach wire. Does anyone have a wiring diagram to show which color wire comes out of the ECM to the existing tach or how to get to it easily? Or know of another way to get a tach wire? Thanks...
I dont know if ours has a conventional tach wire, our ecm works using digital canbus signals. I think there is a half tach signal white wire in the black ecm harness, but you need an adapter to get an analog tach signal if thats what you need for your system. Some have a 2cylinder setting. MSD makes an adapter too.
drse
Dec 20, 2011 03:51 PM
