Various HHR Sub Installs...
Old Apr 3, 2014 | 01:55 PM
  #321
Ironbeard's Avatar
Can you still put the top cover on with the Basslink in the bin?
Old Apr 4, 2014 | 03:44 PM
  #322
Putter's Avatar
Was that question for me? If so, please give me more detail. I am not sure I follow your question.
But, just in case, every stock part that was there is still in place...EXCEPT the plastic recessed panel that once covered the spare tire.
The spare tire is there, the tire hold-down bolt thingie, the movable shelf/floor part....
Old May 11, 2014 | 12:18 PM
  #323
CokeZero's Avatar
Here is the sub I just put in my '11, added it to the factory unit until I upgrade it.
Old Jul 21, 2014 | 04:06 PM
  #324
ShoTym69's Avatar
Smile Radio Install
I have 4 12" kicker dvc L7s, 4 kicker 6x9s, 6 kicker 1" tweeters and 4 6 1/2 alpine spr60s. The 2 sub amps are Earthquake ph10000w/d1 amps and the 2 4channel amps are Earthquake 2200w/d4. Also have 2 stinger 10farat digital caps and 3 stinger batteries and 1 red top optima. The Headunit is a keenwood DVD/navigation Headunit. Got a 240amp alternator installed but plan on upgrading to a 320amp alternator later. The stereo is running around 7000 RMS right now.
Old Jul 21, 2014 | 04:09 PM
  #325
ShoTym69's Avatar
Smile Radio install
Here's the sub's
Old Jul 21, 2014 | 04:10 PM
  #326
ShoTym69's Avatar
Smile Radio Install
And here is the amps
Old Jan 29, 2015 | 06:20 PM
  #327
thornman's Avatar
did any of yall have to change to a bigger altenator
Old Jan 30, 2015 | 07:38 AM
  #328
Yes read post #324 from ShoTym69
Old Mar 19, 2015 | 08:07 PM
  #329
3800seriesII's Avatar
My recent sub replacement
After I got tired of hearing the stock subwoofer rattling, I thought I would go back there and check it out. Turns out the woofer was definitely toast; the cone was literally detached from the coils and was torn at the top. I went searching for a replacement, something simple, and purchased the Pioneer dual 2 ohm 8" shallow mount subwoofer. I am very pleased, while I also used the stock box and amp. Practically a direct fit.
Here is the link:
Amazon.com : Pioneer TS-SW2002D2 8-inch Shallow-Mount Subwoofer with 600 Watts Max Power : Electronics Amazon.com : Pioneer TS-SW2002D2 8-inch Shallow-Mount Subwoofer with 600 Watts Max Power : Electronics
Old Mar 27, 2015 | 07:23 AM
  #330
dpaquin's Avatar
Anyone know where to get a stock sub box for one that didn't come with premier audio?
