VSS speed scensor
Old Dec 23, 2006 | 02:30 PM
chadfosmire's Avatar
VSS speed scensor
I have installed a Pioneer AVIC-D1 in dash nav unit. I am having problems finding a speed pulse scensor.
Anyone know where I can pick this up?
Old Dec 23, 2006 | 03:12 PM
Couldn't get the one in mine to work either.
Old Dec 24, 2006 | 10:07 PM
DesiredCustoms's Avatar
VSS can be grabbed at the vehicle hub on the wheel.
not sure on wiring but thats where the signal comes from
Old Dec 25, 2006 | 12:37 PM
Thanks
I saw in an earlier post that you can get the vss off the ECU con3(gray) yellow wire, but that did not work.
So if you find out which wire on the hub let me know, thanks.
Also, is it easy to access the hub on the wheel?
slimsol
May 1, 2010 09:41 AM
1lowlesabre
Jun 4, 2008 04:03 PM
Clevelandhhrss
May 4, 2008 02:18 PM
