Where is the On-Star module hiding and how do I get to it?
Old Feb 27, 2010 | 12:00 PM
lazaino's Avatar
Well, the title says it all. I have the Costar Bluetar in hand and I can't find the OnStar module to install it. Someone said it was in back on the right side, but I didn't at first glance see how to get in there. Any tricks anyone knows or will it be obvious when I finally get there?
Ira
Old Feb 27, 2010 | 12:22 PM
hvrod's Avatar
Start removing the panels.
Lay the seats down,
remove the right cargo latch bolt
remove the right selt belt bolt
remove the upper small bolt under the tab..
lift out the panel
may have to remove the trim panel in the middle , the one near the
tail gate upper portion ceiling..
Old Feb 27, 2010 | 01:35 PM
lazaino's Avatar
You don't happen to know if the OnStar module is actually back there, do you?
Ira
Old Feb 27, 2010 | 01:54 PM
hvrod's Avatar
if you have the extra antenna on the back portion of your roof you should have one.. also in your rear view mirror you should have the button for onstar,
Old Feb 27, 2010 | 02:36 PM
an08HHR's Avatar
Ira
look at post 5 of this thread https://www.chevyhhr.net/forums/show...ghlight=onstar
This show the on-star module
Old Mar 18, 2010 | 01:59 AM
lazaino's Avatar
It's not fun to get to, it's behind the lower panel on the passenger side. I pulled the top panel and then was able to reach down and get the needed plugs out. I installed the BlueStar 2010 and after setting the volume my wife, it's for her, is really happy. Just make sure if you put one in to run a USB cable to somewhere you can get to as I needed to adjust it with a laptop to get the mic volume correct.
Old May 12, 2010 | 12:12 AM
lazaino's Avatar
Well, in the end, the Costar didn't work in the HHR. It seemed fine at first, but got noisy more and more of the time and then there was no sound out of the cars speakers. Pulled it out, sent it back, he says it works perfect and I got my money back. Sad, because when it worked right, it was perfect. I was really hoping it was broken and he'd send me a new one.
Ira
mitzkity
Mar 14, 2011 11:49 AM
tucsondivots
Jul 22, 2010 11:56 PM
itschaboykenny
Sep 29, 2007 10:53 AM
giant96
Aug 5, 2006 11:48 PM
pjtaxi
Jan 13, 2006 07:51 PM
