Who has a stock 2006 radio?
Old Jan 18, 2013 | 07:06 PM
docohm's Avatar
My stock 2006 radio has very poor AM reception. I know some of that is caused by the crummy little antenna on top. I wonder if this radio has an 'antenna tune' adjustment on the back of the radio? I know some of the older style radios had those. I don't want to take the console all apart just to look for that so I'm hoping that someone has one they pulled out already and could check on that for me. It's usually a tiny hole or adjustment screw near the antenna connection.
Thanks in advance...
Old Jan 18, 2013 | 07:58 PM
Look at the TSBs I think one addresses poor radio reception. If I remember it's because a wire gets loose up top in the headliner. But check to make sure the antenna is screwed all the way on and it has good contact (no corrosion etc.). It is possible get up there without pulling the entire headliner down, but challenging. It is actually fairly easy to pull the waterfall front off, just grab onto the A/C vent holes and pull.
I won't even ask about AM radio, since I usually listen to it, too.
Check your PM for a link to info.
Old Jan 19, 2013 | 05:44 PM
mityqwik's Avatar
Thumbs up
my 2006 has bad reception for the AM channels also,let us know what you find out i would be curious on what you find
Old Jan 19, 2013 | 05:54 PM
Old Lar's Avatar
My 06 came with the six CD changer and I've had no issues with reception. I did have the four door speakers replaced last year. I use the radio/CD for background noise as I drive and to get some local weather news when I'm on the road. ~107K miles on the clock.
Old Jan 19, 2013 | 06:12 PM
andys08ss's Avatar
I looked at my stock radio from my 08 and I do not see any hole, for a way to adjust the tune, again mine is a 08 ,
Old Jan 25, 2013 | 09:13 PM
docohm's Avatar
Working better!
I installed one of these replacement antennas,
http://shop.advanceautoparts.com/web...rchTerm=rm22sb
It's much longer and works much better on AM now.
oliver_cfc
May 29, 2013 09:02 PM
BlackHHR06
Jan 14, 2010 06:46 PM
longislandhhr09
Apr 23, 2009 04:33 AM
HHR PNOY
Apr 6, 2007 09:39 AM
