XM Radio
I don't listen to the radio so I didn't get XM. Even though there are no commercials you still have to listen to crap that you don't want to hear.
Why listen to what you don't want to hear, turn the station, that is what the knob id for!!!!
I personally am likely the XM, gives specicific music genres and more selection, also if you are traveling the stations are always avaialable and you know what you have. There are commercials, though, not as frequent.
Too each his own, and Captian, just playing with you!!!
Later
Its kind of like when I listen to music choice. Even if I'm listening to a type of music I like I still hear stuff I dont like. But at the same time one can argue that you get introduced to new music that you will like. XM is cool but its something I thought I didn't need.
Took the HHR into the dealer today and they fixed the radio. The problem was in the fuse / wiring. They removed the fuse and put it back in and the XM portion of the radio started working.
Only comment from the service manager was that if it fails again then it might be with the radio and they will replace it.
I had gone into the fuse box and pushed down on all of the relays earlier and all of them were not seated properly. Life goes on.
Sno White
"How To" Tutorial Library
11
Aug 26, 2009 05:48 PM
