XM Radio Upgrade Questions
I apologize if these questions have already been answered. I am an audio amateur, so please be patient with me.
I am the proud owner of a 2008 SS with the upgraded stereo/6 disc cd changer (non XM). Is it possible to simply replace the radio head unit and install a factory GM unit that will work with XM? Is the XM antenna already installed, or do I have to have that installed as well?
I am currently a Sirius subscriber, and now that XM and Sirius are the same, I'd like to ditch my plug and play Sirius receiver.
Thank you in advance for your input.
I detailed to them that I had the upgraded stereo with the 6 cd changer. I mentioned that I had an HHR SS, but I neglected to tell them that I had OnStar, as I thought that it was standard.
So I guess the real question is whether the XM antenna is actually installed. I have OnStar and the upgraded (non XM) stereo system.
Thank you.
Your radio should be XM ready unless they changed something, I have an 06 and my radio is XM ready. As far as I understand it the Onstar antenna will need to be switched with an Onstar/XM antenna which should be included in the kit from GM. Here is a thread where someone had the kit installed. https://www.chevyhhr.net/forums/audio-video-17/xm-installed-17272/
