20's and springs
Old Jul 25, 2006 | 09:02 AM
crowbar's Avatar
and the ride is harsh sometime.
uh........... no its not, it rides like everyone else's with goldlines
Old Jul 25, 2006 | 10:08 AM
HHR PNOY's Avatar
he has 20s by 8.5 i think and he has the goldlines, and the ride is harsh sometime.
06...do you even know what goldlines look like, let alone ride in an HHR with goldlines?
Old Jul 25, 2006 | 10:30 AM
crowbar's Avatar
i know. we need a sticky: dont base your aftermarket parts spending based on 06chevyhhr's comments......... he cant even drive yet
Old Jul 25, 2006 | 11:40 AM
SCOOT's Avatar
Originally Posted by EL_REY
... not have to "roll the fender", BTW whats that mean, and what do you do to the fender??
Seeing that this specific Q hasn't really been addressed, here's my long-winded attempt.
'Rolling' relates to reducing (or eliminating) the body metal that's bent INTO the fender well from the factory. The same can be achieved by grinding the lip off... as Crowbar has previously stated. Either way, the end-product is that you have MORE offset (clearance towards the OUTSIDE/exterior of the vehicle) in the wheel well .
As you know, or have read, the HHR will only accommodate certain rim widths *without* rubbing. Rolling will aid in giving the additional clearance needed without having to do other, more drastic, modification (e.g. body work, etc...). Please note the obvious- a 10" wide Vette rim, or similar, WILL still hit!!!
A note on lowering...
Dropping the HHR (any drop- any vehicle) will reduce the amount of factory 'cushion' (travel space) the wheel assembly needs for absorbtion when hitting a bump/loading the suspension. Granted, lowering generally equates to a stiffer suspension (which inherently means reduced wheel travel) ... but ( stick with me here) it still puts the whole vehicle (that is- parts that are mounted ON the body springs) closer to the ground. A side affect is it also happens to put these 'dropped' parts (e.g. body) closer to other parts (like suspension components) that 'move' which might result in 'rub'.
Sometimes the lack of 'cushion' isn't a problem for substancial drops (factory rim widths), whereas for others- it IS (wider, non-factory rims + lowering).
LASTLY ()... The whole 'rubbing' problem should only happen under certain circumstances (that compress suspension- reducing travel), such as: hauling heavy loads (e.g. stereo equipment)/multiple people, hard cornering (auto crossing), hitting large bumps/pot holes (unavoidable).
(whew) ... hope this helps clear things up.
Old Jul 25, 2006 | 05:17 PM
O6ChevyHHR's Avatar
yes i can i have my lisence!
Old Jul 25, 2006 | 05:52 PM
captain howdy's Avatar
Old Jul 25, 2006 | 07:49 PM
O6ChevyHHR's Avatar
thanks CH !
Old Jul 25, 2006 | 07:52 PM
thanks CH !
OH MIE GOD, HE SPELLD AWL THE WORDZ RITE!!!
Old Jul 26, 2006 | 07:40 AM
Now, if he can just work on his punctuation!
Old Jul 26, 2006 | 02:33 PM
crazybob's Avatar
L I C E N S E .
