ABS repair
Old Apr 2, 2020 | 10:56 AM
kmcfall48's Avatar
my question was .... in an effort to find a wiring diagram for the abs system.
Old Apr 2, 2020 | 11:08 AM
Post #2 in this thread
https://www.chevyhhr.net/forums/brak...-wiring-59462/
Old Apr 2, 2020 | 03:35 PM
kmcfall48's Avatar
Thank you OldBlue, How can I find other diagrams for the HHR????
Old Apr 2, 2020 | 03:59 PM
I used our search window, HHR wiring diagrams ABS
Old Apr 2, 2020 | 04:55 PM
Gee; 2 wires from each wheel to the EBCM.
Old Jul 30, 2020 | 12:25 PM
kmcfall48's Avatar
ABS repair
Hi! I have a 2010 HHR LS. I have had the "ABS" light on for a good while. Over the years, I have changed all four wheel bearing ( which include the wheel sensor), because they had close to 200K miles on them. I have found a break in the Right Rear wheel sensor wire next to the wheel hub, and repaired it. The ABS light was still on.....? I have found the pinouts of the electrical plug for the EBCM. I disconnected the plug and ohmed out the wires leading to each sensor. I found that the front sensors ohm out, but the rear sensors read as an open circuit. Question:I would like to know the path the sensor wiring takes thru the body of the car. Any thoughts?????
Old Jul 30, 2020 | 12:52 PM
to the forums!
You've had a warning light on for your brakes, for years? And you've never had the codes read?
Old Jul 30, 2020 | 02:04 PM
Welcome to the site, there’s a wire diagram here somewhere
https://www.chevyhhr.net/forums/www....ad.php?t=59462
as for physical location of the wires , they usually just run from the hub to the body in each side, now I haven’t seen to many where the wires were damaged in the body cavity, just in the exposed areas
here are a few photos of the rear ABS harness photos in this for reference
https://www.rockauto.com/en/catalog/...+connector,762
Old Jul 30, 2020 | 02:28 PM
(this is just a continuation of his other thread about an ABS problem )
Old Jul 30, 2020 | 03:16 PM
Merged
