Alignment after Lowering
Old May 10, 2006 | 12:00 AM
  #51
ng8650's Avatar
Originally Posted by cjuetten
99.9% ?? Did you actually survey 1000 HHR owners that lowered their car AND installed camber bolts
or are these numbers you just pulled out of thin air.
Just
Lets see.... I didn't install camber bolts and my camber was out of spec just curious what the odds were for that?
Wow if your camber was out of spec, you may want to look into that. GM gives us a lot of room to play with, that's why most of us don't require camber adjustment. Now Toe, so far everyone who I've heard from has needed adjustment, including myself. Are you talking about Camber or Toe?
Did you use Goldlines? If so then you are .0002% in other words you are only the second person I know of who needed camber adjusted after installing dropped springs. But If you didn't use Goldlines, then that changes everything...
Ng
Old Dec 11, 2012 | 09:57 PM
  #52
Man this is a dusty one, guess no one has adjusted camber in years.
Old Dec 11, 2012 | 10:41 PM
  #53
Well, since you dusted it off.
After putting my SS on Pedders, I had it checked. Camber was OK but had to adjust the toe. Simply put. It was a small bit pigeon toed.
Old Dec 11, 2012 | 10:42 PM
  #54
tracy waddell's Avatar
Haven't had to, everything is still running true.
Old Dec 12, 2012 | 06:23 AM
  #55
The KW's have me lower than Pedders, my camber is .10 and should be -1.8 to -0.3. Think I will order the cam bolts.
Old Dec 12, 2012 | 11:52 AM
  #56
-1.8 to 0.3? Those numbers seem different that what I have.
Old Dec 12, 2012 | 12:54 PM
  #57
IgottaWoody's Avatar
Both mine had to have toe changes..one on GL..one on SL's.. and camber can be affected on how struts are installed..theres just a smidgen of play in the bolt holes so when installing the bottom strut bolts make sure you pull out at the top bolt(or push top of spindle in) before tightening or it will suck in and camber the tire top in..had a slight pull once and doing this cured it. The camber was noticable looking at it...
Radco
Maintenance and Upkeep
Apr 25, 2013 08:23 PM
Wrenchbender Ret
Feb 27, 2011 10:36 PM
baldycmw
Aug 29, 2008 05:17 PM
paireno
Jan 4, 2008 03:29 PM
traketo
North East
May 30, 2006 04:46 PM
