Brake Rotor Upgrade How to (56k beware)
This is a great "how to" on installing rotors and it was a big help to me. I would like to point out however that it is only necessary to remove one of the lower 15mm bolts from the calipers. The short bolt towards the front must come off, but not the blue bolt. It is not a part of the caliper. If I am wrong and my wheel is about to come off going down the road, someone please correct me quickly!
Also, with regards to "directional rotors" - my rotors are EBC and are drilled and slotted. They are marked "R" and "L" on the rotor. The fins inside are not angled, so apparently EBC has the belief they should be put on a special way.
For whatever reason, my brakes worked great for about 1500 miles, then began vibrating worse than ever. Even now, with the rotors switched to the proper side, you can feel them shaking when I apply light pressure to the brake pedal at speeds over 40 or 50 miles per hour. According to the EBC website, this is due to variation in the rotor thickness and they must be cut. They also say to replace the pads. That seems awfully expensive, since according to their website the pads take about 2000 miles to fully break in. Since they are softer than the rotors, wont the old ones wear in if I just recut the rotors?
Hey Lee, Did you have your EBC rotors turned. I'm going through the same rotor crap with my HHR. Thinking about a set of R1 Concept rotors when the weather warms up a bit. My wife's 08 has never had the problem with 15K miles. Good luck with your brakes!
BTW: there was no R or L on my rotors and R1 Concepts said they can go on either way it does not matter. The part numbers on the boxes are the same, no left or right noted. I saved my factory rotors in the R1 boxes.
Actually, the Zinc plating wears off od the brake surface within a few thousand miles and then just like the stock rotors they rust very quickly. They will flash over with rust while I am washing the car just like the factory rotors. The hat and outer edge of the rotors stay silver and rust free so far.
I love your pictures and the outcome Looks great! I have one question, how do you keep the brake dust off of your pretty wheels? I have an 08 SS five speed and no matter how light I use my brakes they are always black by the end of the week.
Seriously...
