Brembos up front, Disc Rear on 06 2LT
Old Apr 23, 2014 | 06:14 PM
  #71
jschmieding's Avatar
Originally Posted by phrog fixer
Just bought a rear bear from an 07 Cobalt SS for my HHR. The guy cut the emergency brake cable, so any info on where to buy new cables? (Besides the dealer) Thanks
Rockauto.com
Old Apr 23, 2014 | 07:42 PM
  #72
phrog fixer's Avatar
Thanks, light went off after I asked. Saw Rockauto had them.
Old Apr 24, 2014 | 03:19 PM
  #73
pbatmen's Avatar
just make sure its for the 2007 cobalt ss, not a standard HHR with Drums, it will fit perfect and help with the pedal feel when you adjust it.
Old Apr 24, 2014 | 04:37 PM
  #74
?? my HHR doesn't have ABS, the rear beam I bought has ABS hubs. So I should be able to buy new NON-ABS drum hubs and use them on the rear disc, right?
Old Apr 27, 2014 | 09:31 AM
  #75
SHAKIRO69's Avatar
HEYYY, I NEED HELP, I HAVE AN HHR 2010, DRUM BRAKES ON REAR, AND I'M CHANGING IT TO DISC BRAKES, I HAVE EVERYTHING, THE DISCS, PADS, CALIPERS, BUT I NEED THE Rear Adaptor Bracket Caliper Mount Backing Plate SO I CAN FINISH INSTALLATION, COULD ANYBODY KNOWS WHERE CAN I GET IT? THE PART #? OR INTERNET SITE THAT HAS THEM? OR HOW IS IT CALLED? PLEASE? THANKS
Old Apr 27, 2014 | 10:18 AM
  #76
No need to double post.
As stated in the answer to your other post, you need the rear axle assembly from a disc brake car(SS axle) to do this conversion.
Don't recall a "rear adapter bracket". Even if there is one, it would be a weld on modification, not a bolt on.
And a little P.S. You might want to lose the Caps Lock. Kind of annoying.
Old Apr 27, 2014 | 11:55 AM
  #77
The hubs are interchangeable. One has the tone ring & connector, the other doesn't.
Old Apr 27, 2014 | 06:05 PM
  #78
That is what I was thinking.
Old Jun 30, 2014 | 12:50 AM
  #79
GreasySpoon08's Avatar
does anyone have a link to a site where i could find a rear axle of an ss cobolt :)
thanks.
Old Jun 30, 2014 | 04:49 AM
  #80
Gary B's Avatar
Try this guy. That is what he does for a living. He parts out Cobalt SSs.
reiland5@aol.com, his name is Jeff
