Caliper pins
Old Apr 1, 2015 | 06:56 PM
hurst2001's Avatar
Caliper pins
Well I was doing my brakes up front and on my passenger side top pin was a little taller then the other pin . .. When I went to put the caliber on with the new pads it would not fit.. So I had to like screw the one in so the caliber would fit .. So my question is do you tap these out to grease or do they screw them out? Never mess with them do not sure ..
Old Apr 1, 2015 | 07:04 PM
Lucky's Avatar
They should just pull out but I have seen them seize in the adapter.
I try to free them with a little twisting motion to brake them free. I have had to use some heat to free then if there realy stuck in there.
Old Apr 1, 2015 | 07:29 PM
To begin, you do not need to remove the top pin at all. Just remove the bottom one then flip the caliper up.
You did notice the squared bits that line up to the caliper to idiot proof it, right.
If you pull the pins you should put some caliper grease on them.
Old Apr 1, 2015 | 07:50 PM
hurst2001's Avatar
Yes
I did notice that squared bits line up to the caliper .. So you only lube the bottom one only?
Old Apr 2, 2015 | 06:11 AM
I don't normally remove the pins, unless I am going to lube them. Just the lower bolt is enough to do pads.
Brembos may be different, if you got them.
Old Apr 2, 2015 | 07:19 AM
He is listed as a 2006 so it won't be an SS with Brembo's. However those pins the top one is longer and I always remove both to clean and lube them every pad change!
Old Apr 3, 2015 | 05:04 AM
hurst2001's Avatar
It is a stock 2007 ls and thanks on advice I will do both top is longer bottom shorter..
MichiganMarty
Maintenance and Upkeep
19
Jan 27, 2021 06:59 AM
carsrmilife
Aug 14, 2014 03:11 PM
Ken
Apr 16, 2012 08:24 PM
voigtsga
Sep 11, 2010 09:54 AM
Jizz
Nov 3, 2006 06:15 PM
