Cobalt SS Struts?
Old Dec 2, 2010 | 11:55 AM
SmootHHR's Avatar
Cobalt SS Struts?
So...have some new springs headed my way (Thanks again Rally!) and I need to start thinking about some new front struts. Prolly need them soon anyway, since the stockers have 106k on them.
In doing some research, I found that there was some good points made about matching spring rates with comparable shocks and struts. Igotawoody seemed to hit it best, if I recall correctly. So, the springs came off of a 2006 SS Cobalt...is my thinking that new struts for a 2006 SS Cobalt on my 2006 HHR off base? Would this set up work? I know that Koni makes a fine product, but they are pricey. I'd love to stick with OEM parts that I know are going to mesh/fit. Also, I've replaced the rear stock shocks with KYB's. I recall seeing a post (don't remember which thread) that said LT/SS rear shocks have the same part number? Am I going to be ok or will lowering the car on SS springs be tough on the new KYB's that I installed?
This is my first venture in to suspension modification, so please excuse me if my questions sound a little dumb
I know there are a lot of intelligent folks on here that can shed a little light on what I'm getting in to. Always open to suggestions. Thanks in advance!
Last edited by SmootHHR; Dec 2, 2010 at 11:57 AM. Reason: Car doesn't have rear struts...doh!
Old Dec 2, 2010 | 12:21 PM
The SS springs will be fine with the KYB shocks in the back and why not go for KYB struts up front. Should be a perfect match.
Old Dec 2, 2010 | 12:43 PM
SmootHHR's Avatar
Def thought about that^^^ I'll check the part numbers for a SS Cobalt strut and a HHR strut to see if they match. Keep the suggestions coming!!
Old Dec 2, 2010 | 12:55 PM
Mrs. DLVRNIT's Avatar
Hey Smoot,
Were thinking you are wanting to install the springs front and rear? The KYB's you are refering to were there version of GM's FE3's we believe so you would want to match with a GM FE3 strut! KYB's shock / strut is a replacement comparable to the FE3 and not the SS FE5 version! Our suspension parts are SS's but are of the FE5 version! So in a nutshell if wanting a GM match to your KYB's, the GM FE3 strut should match!
Best-O-Luck ,
Old Dec 2, 2010 | 01:25 PM
SmootHHR's Avatar
Much appreciated info, as always.
Old Dec 2, 2010 | 01:38 PM
Hey Smoot,
Here's the KYB match to your Rear Shocks and there very reasonable in price:
http://cgi.ebay.com/ebaymotors/KYB-3...item3a5efb77d4
Now just don't ask if we can install them to, haha.....
Best-O-Luck ,
Old Dec 2, 2010 | 07:21 PM
djr1973's Avatar
Best-O-Luck ,
They really arent that bad to change, been there, done that,lol.
Old Dec 3, 2010 | 06:53 AM
SmootHHR's Avatar
Just let me know when you want to come down
Old Dec 3, 2010 | 09:42 AM
djr1973's Avatar
Do you have a garage Rob? I will come down and help ya, let me know when you get all your parts,lol.
Old Dec 3, 2010 | 10:32 AM
SmootHHR's Avatar
I do, but it's tiny
My buddy has a pole barn we might be able to use. It's where he stores his '57 BelAir
