Drilled/slotted brakes???
For the record; I have nothing against the use of any of these rotors. And for the most part, aside from an increase in dust levels, they certainly won't hurt. I'm only trying to educate a bit- changing the rotor doesn't change the braking.
the dealer has said they are special rotors that will warp and unwarp to prevent permanent damage.
Thanks everyone
[/QUOTE]
Yea. they are made by the same company the manufactures the Flux Capacitor that makes time travel possible.
Thanks everyone
[/QUOTE]Yea. they are made by the same company the manufactures the Flux Capacitor that makes time travel possible.
Yes they did. When I was in for my broken sunroof windscreen, I mentioned the rotors to the service guy and he said they do that. I just said whatever because my car was out of warranty anyway so it didn't make sence to argue with a liar and an idiot.
This is an old thread, but I recommend everyone read paragraph 5 at this website (EBC Brakes http://www.ebcbrakes.com/Assets/typicalq%26a.html) EBC contends that people like myself who drive more on the expressway at "off brake" conditions (I have an 80 mile one way commute) are causing the shuddering in their brake rotors just by driving and that it will occur like clockwork at 3,000 to 4,000 miles. I have a 2006 2LT that has been to the dealer three times for this problem. There is some food for thought in this article.
I suppose there is not a flat rate mechanic in the dealer world who would take the time to either check runout with a dial indicator or clean a hub satisfactorily before installing/re-installing a rotor. EBC contends (as I read it) that if you fit the rotor for minimum runout you will be vibration free. This could take several trial and error fittings it would seem, but somewhere in the mix of moving the rotor around one bolt hole at a time I guess you could find the sweet spot with lower than .005 variation.
Bottom line here, there is a LOT of work being done for nothing. According to EBC "driving" the car is what is causing the brake shudder.
I rode my brakes slightly on the expressway last week and believe it or not the brakes were BETTER after I did this. I figured if there was a microscopic variation, perhaps a little friction might smooth it out.
My dealer told me all kinds of silly stuff like "avoid puddles" and a whole list of other stuff that from what I read in EBC's Q&A fails to apply.
