Drilled/slotted brakes???
Old Mar 9, 2008 | 08:19 PM
  #61
hhrbama's Avatar
I went to Auto Zone Friday evening and purchased two new rotors and a set of semi-metallic non asbestos (organic) pads. I did the work Saturday and replaced rotors and pads. I burnished the hub surface and the inside mating surfaces of each aluminum wheel with a wire brush in a drill. The wheels were torqued to 100 Lbft. following installation. I will hit the expressway Monday morning so we will see if getting rid of the ceramic pads helps the oscillation recurring at 3K to 4K miles.
I also got a new set of BF Goodrich Traction T/A tires (215x50x17) installed Saturday morning. I wanted to do the brakes after the tire replacement to assure the wheel torque and rust cleanup. Another user posted some pics in a thread here showing how he had cleaned up his rotors in the wheel mount area. I went one better and cleaned the actual hub and treated it with Amsoil Metal Protector. Hopefully this entire process will alleviate the pulsation in the brakes.
Neudy
Dec 7, 2013 05:45 PM
alexrckid
Maintenance and Upkeep
29
Oct 18, 2011 12:16 AM
relicstone
Apr 1, 2008 07:21 PM
R CA HHR
Oct 26, 2007 10:05 AM
