eibach for the ss
Old May 15, 2010 | 09:00 AM
jas89tta's Avatar
I installed Pedders on my SS back in Sept and really like the look and ride no issues at all.
Pic
Old May 18, 2010 | 09:57 PM
IgottaWoody's Avatar
I think they should come from the factory lowered...........
Old May 18, 2010 | 10:56 PM
peevlos's Avatar
I second that!!!
So as far as the rake thing goes... yes fwd sit lower in the front, yet I was still sitting with different measurements then they state on their site. I was lower in the front and higher in the rear. giving it over 3x's more rake then they say they will.
That said... after speaking with Mike at PeddersUSA he suggested putting some weight in the back and loosening up the control arm bushings to let them reload. This did in fact lower the rear by about 3mm after removing the weight. not much, but I'll take it
while I had it up on ramps I noticed the rear springs where still not seated as far down as they could be around the plastic seat liner thingys. there was still a gap between the spring perch and the spring. I removed both springs and using a piece of wood, a piece of leather and a large bench vise, I was able to press the liners fully into the springs. (dropped another 12mm or so)
I am waiting a few days to remeasure to she where she finally sits. should now be resting closer to the 605 mm front/612 mm rear although my front is sitting at 599 mm already
Still loving 'em.
Gotta say... seeing your pics last year, is what made me decide to go with Pedders
Old May 18, 2010 | 11:17 PM
moonsign's Avatar
I'm going with Pedders springs[Will order next week]. been saving up to do more mods, and looks like I'll be seeing the UPS truck quite a bit soon.
Doing Pedders springs, OTT sway bar, Drag 34[wire mesh]wheels, front splitter, tinted headlights in the next week or so.
Decided to go with Pedders.
P.S. My SS wheels will be up for sale soon[6500 miles-cherry]. Any Nor-Cal guys intrested. "Moon" Hayward, Calif.
Old May 30, 2010 | 10:38 AM
Hotrodbob's Avatar
Just bought an SS and it needs to be lowered, but I don't want to mess up the handling. What are the spring rates of the Pedlers, Eibach, gold line compaired to the stock SS?
I had Eibach on mt LT Panel and they were great, but non-ss cars came with a soft ride to start with and the SS is firm. I also still have my Progress Sway bar (rear). Do they help the SS?
Old May 30, 2010 | 11:03 AM
peevlos's Avatar
I do love the Pedders. took a little bit of work to get the rears to fully seat but it was worth it. rides great... better then stock. Of course they are a little stiffer over bumps...
Pedders site:
The current ride heights are 605mm front (220006) and 612mm rear (220007). This is a rare case where Pedders made the decision to use almost exactly the same rate coils than the OE spec. GM has done a great job with the SS series., but lower is not only better looking but handles unbeliveably well. The result is a car that has been dropped and retains EXCELLANT ride quality with the improved handling. All the benefits you would expect from lower centers of gravity are there with almost no negatives. The torque steer is still there, but reduced.
Old May 30, 2010 | 11:42 AM
JJ's BLACK SS's Avatar
i thought they came a little lower that the ls
Old May 30, 2010 | 06:02 PM
Hotrodbob's Avatar
Yep, if I remember the hype back when they came out it was about 1 inch. When next to a LS or LT you can see that the rear is lower. Still not low enough for me.. Like my kid says, if it's to low or to loud for you, then you're too old.. I'll never grow up.
If the Pedlers are the same rate, then I can just cut a coil out of the stockers and save the $$$.
What about the rear sway bar. Anyone add one to an SS?
Old Jun 1, 2010 | 11:00 PM
Can't cut the rears without torching the ends and we all know thats a bad idea....add the rear bar, dont ask just do it!
Old Jun 2, 2010 | 06:35 AM
peevlos's Avatar
Agreed
Cutting the springs = bad idea. Rear bar = good idea
bar definitely improves the handling in the SS
