Famous Clunk.. Suspesion question.
the sway bar bushings are easy peasey, check these from the search window
www.chevyhhr.net/forums/showthread.php?t=35868
www.chevyhhr.net/forums/showthread.php?t=39813
i read those, thats what made me try, i did try but just cant seem to get them. i saw blue ones that looked like ours but now i cant find them. im hoping thats where the clunk is coming from is them bushings.. only thing left to do.
ill prob use just stock, i just didnt wanna replace it again for a long arse time. only reason we had to replace it all this time is cause the car was given to us. her dad said the mechanic fixed this n that.... however he didnt... so i got stuck with it all.
I have a clunk sound when I turn the wheels left and right quickly and also whenever I hit a bump, it really sounds bad turning left and right quickly I've changed the struts both sides and the bearings on the top but still clunks, does anybody know what it is?
A quick "SEARCH" will turn up hundreds of posts about the clunk. Most likely sources are 1.sway bar links or 2.sway bar bushings, next is 3.Lower Control Arm bushings.
check out the part numbers at: Part Numbers for illusive and common parts: https://www.chevyhhr.net/forums/commonly-used-part-numbers-68/part-numbers-elusive-common-parts-broken-into-separate-posts-thread-48833/
Donbrew- I just wanted to let you know what a great job you are doing as a moderator. I can almost hear your teeth nashing when someone asks a question that has been asked a hundred times. I am impressed with your restraint.
