Found the fix
Old Mar 9, 2013 | 01:10 PM
dustin6119's Avatar
Found the fix
Well front end had a shake.....after changing rotors and pads twice ( another story) and rotate and balance the tires.....turned out to be a need for a front end alignment....HHR is now as solid as a rock and handles very well...
I will be replacing the front struts soon and wanted to know what the best replacment would be...FYI I dont do track days or run it hard just a daily commuter on twisty county roads..
the other story is when chasing down a pull to the right and a certain metal grinding noise,,,, com to find out there was a lead stick on wheel weight stuck between the pads and caliper piston....and even after that still had some noise so I swapped back to standard replacement smooth rotors and ditche the drilled and slotted ones....now it stops nice and quiet and smooth and straight...hope this helps anyone with similar issues.
Old Mar 9, 2013 | 03:59 PM
VinceP's Avatar
Glad you got it sorted out. As far as the struts, I installed KYB's on my 08 Panel and I am very happy with them. No harsh ride but handles better than stock.
Old Mar 9, 2013 | 04:07 PM
dustin6119's Avatar
Vince, do you have a link?
Old Mar 9, 2013 | 06:44 PM
Silverfox's Avatar
What suspension do you have ??
FE1 ... FE3 ... FE5 ?
Old Mar 10, 2013 | 08:32 AM
dustin6119's Avatar
I don't know??
Old Mar 10, 2013 | 10:04 AM
IgottaWoody's Avatar
Looks to be an LT..either way the KYB's should work fine..
Old Mar 10, 2013 | 11:17 AM
VinceP's Avatar
FE1 suspension. I purchased the struts from Rockauto.com. They were the cheapest I could find at the time. Part numbers were KYB 339085 and 339084 for the struts and KYB SM5513 for the strut mounts.
Hope this helps.
Old Mar 10, 2013 | 03:01 PM
dustin6119's Avatar
the KYB is it a better performing strut or just cheaper?
Old Mar 10, 2013 | 05:00 PM
VinceP's Avatar
Performs way better than stockers. I should clarify. When I said the cheapest I meant that Rockauto had them cheaper than everyone else. Not that they are cheap struts.
I don't have much faith in Monroe any more. The last couple of sets of shocks I purchased of theirs did not make the cut.
I have had the KYB's on for about 35,000 miles and still feel great. I will purchase them again when needed.
Old Mar 10, 2013 | 07:41 PM
dustin6119's Avatar
thanks Vince, The stock ones I have now are just starting to weep a little bit so I might stretch them out a little longer...
ChevyGuySS
Oct 30, 2012 09:12 PM
PaperChaseHHR
Sep 12, 2012 08:55 AM
tooter1
Feb 15, 2009 01:29 PM
xzombiex66
Sep 22, 2008 09:31 PM
Wheelie7
Oct 10, 2007 07:57 AM
