Front Control Arms
Old 08-07-2018, 11:33 AM
OldSwede's Avatar
Front Control Arms
So, OK, I am just back from the shop and I need new front control arms and struts. Looking to order from Rock Auto. Are the AC Delco OEM control arms preferable to the MOOG, or vice versa? The MOOG are considerably cheaper, both are cast and not sheet metal.
OldSwede is offline
Old 08-07-2018, 02:43 PM
OldSwede's Avatar
Never Mind
I had to order to meet a schedule, so I went entirely with AC Delco - control arms, struts and shocks. Amazingly, according to my mechanic, sway bar bushings look fine.
OldSwede is offline
Old 08-07-2018, 04:03 PM
You’ll be fine with that order.
Oldblue is offline
Old 08-07-2018, 04:12 PM
OldSwede's Avatar
Thanks.
David
OldSwede is offline
Old 08-07-2018, 08:24 PM
Did you remember the discount code?
Oldblue is offline
Old 08-07-2018, 09:44 PM
OldSwede's Avatar
....sob........
OldSwede is offline
Old 08-08-2018, 06:43 AM
HHRerrr's Avatar
OldSwede….how many miles on the sway bar bushings? I would replace them as well if they are as old as the rest of the front end....regardless of how they 'look'. BTW, I feel you made the right choice on the LCA's.
HHRerrr is offline
Old 08-08-2018, 06:55 AM
OldSwede's Avatar
164k. Your concerns are noted, and much appreciated. I assume that I should just order the end links?.
OldSwede is offline
Old 08-08-2018, 07:07 AM
HHRerrr's Avatar
10-4.....ones with the grease zerks
HHRerrr is offline
OldSwede's Avatar
Never mind my ignorance. I am new to the HHR "experiemce". I ordered sway bar bushings just now.
OldSwede is offline
Quick Reply: Front Control Arms
