Front lower ball joint replacement 2006 LT
Old Apr 10, 2012 | 06:13 PM
ChevyMgr's Avatar
Originally Posted by barfan1
If you are doing the tie rod ends, you may want to check the struts, strut mounts, sway bar links and bushings, and the rear lower control arm bushing as these all fail quite often on the HHR. The factory tie rod ends and ball joints are both pretty good so you're rattle may not be the tie rods.
My thoughts too, especially the strut mounts, links and bushings.
grace718
Jan 21, 2021 02:39 PM
55f250
Aug 8, 2010 09:49 PM
rski
Feb 25, 2009 06:57 PM
