Front strut service life ?
Old Jan 15, 2011 | 07:23 PM
foolmoon_design's Avatar
Originally Posted by THE BATMAN
My first struts lasted 32,000 miles. At 60,500 miles , I'm probally about due.
What did you go with? something rated for the fe5 option I hope. OE?
Old Jan 15, 2011 | 11:14 PM
IgottaWoody's Avatar
Correct, the valving doesn't wear out....but the oil gets hot and breaks down (fade come to mind?) also seal and whatever particles accumulate and can affect the flow thru the valves..tell a racer his shocks never change and he'll save thousands a year not having to rebuild them................
Old Jan 18, 2011 | 03:49 PM
meistromichael's Avatar
Started having issues with mine at 106,xxx. I've had the car since 28,xxx and haven't replaced them yet. I've now ordered some KYB's.
Old Jan 18, 2011 | 06:04 PM
jay loukakis's Avatar
Originally Posted by Lucky
struts are an big money maker in the repair industry. if the oil or the gas&oil inside a strut don't leak out the struts don't lose there damping ability. so unless its making noise,rusted out or the valves inside have broken which is very rare it should in no way be unsafe. I have seen lots of struts go for 100,000 mile plus and they are still going strong with no excess tire wear or danger. This is my opinion based on being an auto tech of 18 years. with that said if you have the money to send and you want peice of mine then by all means replace them as often as you like but I beleve that there money will better spent fixing the noise which is probably sway bar links and or bushing as was mentioned by 843de above.
I just had the links replaced went with the Moog the bushings were fine but have ordered the regreaseable one wont be here until next week, rides like new.
Old Jan 18, 2011 | 06:14 PM
THE BATMAN's Avatar
What GM supplied for free OEM - (crap)
Old Jan 18, 2011 | 06:44 PM
Lucky's Avatar
Glad to here it worked out for you. let me know how the greaseable bushing work for you. I have never seen how those work or what they look like.
Old Jan 18, 2011 | 07:16 PM
bushings
www.energysuspensionparts.com greaseablr Sway Bar Bushings 1 inch/25mm $15.99 plus shipping those that have gotten them like them,
Old Jan 19, 2011 | 05:37 AM
solman98's Avatar
I'm at 59k and I'm looking at new shocks/struts this srping when it warms up. I can tell they are getting due. Looking at KYB's.
Old Jan 19, 2011 | 07:52 AM
mrarff's Avatar
Monroe offers a strut that comes with the spring installed, along with the strut install kit that holds the top of the strut to the uni-body. Having the spring installed saves labor and replacing the mounting parts at the top are a really good idea also. I'm at 48K on my 08 2LT and I've got two on order. I replaced the rear shocks this week with Monroes (around $58 ea) And the Sway end links were swaped out for Moog units ($34 ea). The 2 strut kits were $277 and change shipped From Discount auto parts.com. partstrain.com has pretty good deals and good service also. Just my 2 cents.
Old Jan 19, 2011 | 08:42 AM
SmootHHR's Avatar
I just did KYB's up front with the SS springs
Anyone ever see a floating HHR? haha
To the best of my knowledge, the previous owner never did front struts on my HHR...I've put 20k on it (108k now) and just did the struts. They were absolutely smoked! Next to NO pressure on them at all. We turned them upside down and stood them up on the "post" and the weight of the strut itself started to push the post in. To my surprise most, if not all, of the clunks are gone in my car. Shoulda done them with the rear shocks I did this summer, but didn't have the loot. BTW, my struts were NOT leaking, so for what it's worth, the "if they not leaking they not broke" theory isn't correct, at least in my case.
