Front Sway bar bushings
Old 01-24-2012, 07:29 PM
  #61
alexrckid's Avatar
Originally Posted by prod
You are looking at part #5, the clamp bolts and nuts are tightened to 37ft/lbs. Cut line of the insulators face rearwards.
good front end blow-up.
alexrckid is offline
Old 08-12-2013, 10:47 PM
  #62
dirtydoug0070's Avatar
I have a 007 HHR LT that makes a fast knocking noise when I hit the brakes a little hard. I just took the car in today to a so-so shop for repairright control arm.s. They replaced the front struts and lower right control arm. I originally wanted them to replace the sway bar bushings and links, but they said they were ok. I jacked up the car tonight and I could put a screwdriver between the bushing and the sway bar. Could the bushings be making this noise or could it be the brakes. Thanks
dirtydoug0070 is offline
Old 08-13-2013, 12:24 AM
  #63
Could be the sway bar bushings - esp. if the road is not laser smooth. The bushings are definitely shot if you can poke a screwdriver between them.
whopper is offline
Old 12-02-2013, 09:00 PM
  #64
Vandan's Avatar
dirtydoug0070… I have the exact same symptoms…hit the brake hard and there is a fast knocking sound that sounds like it is only on the front drivers side. I replaced the tie rod end tonight, but the knock is still there. I don't think it is the end links (Moog greasable ones on there right now). There doesn't seem to be any play in them. I also don;t think it is the sway bar bushings, did those a year ago or so and they seem fine. My guess is something with the steering rack, but can't quite figure out where the bushing is on that.
Vandan is offline
Old 12-03-2013, 01:07 PM
  #65
No bushing on the rack.
Lower Control Arm bushing? That's my guess.
donbrew is offline
Old 12-03-2013, 05:34 PM
  #66
Vandan's Avatar
I'll have to head back to my local NAPA because I thought one of the guys there said that they had problems with their HHR and had replaced the bushing somewhere on the steering rack/column/... I'll see if I can get the lower control arm bushing to flex with a crow bar. My wife did hit a curb last year in the snow and we had to have the drivers side control arm replaced… It has been good until recent.
dan
Vandan is offline
Old 12-03-2013, 05:46 PM
  #67
dan
The bushing wears out. You need to visually inspect it. It is has holes in it from the factory, but they get shredded. A screwdriver and a flashlight is all that's needed.
Use the SEARCH box, there is lots of info about them.
Other things, since it's been replaced is check the torque specs. Struts bent/broken/worn out.
The only bushing in the front that I am aware of are the sway bar and sway bar links and LCA. Parts Counter guys are usually no smarter than you.
donbrew is offline
Old 08-30-2014, 07:04 PM
  #68
bluetwofour's Avatar
hello all, great forum!
not to start up the old thread for these sway bar bushings, but...
jacked up the car on driver's side. front (15mm) bolt out just fine. back (10mm) would not budge! used 3/8 drive ratchet with short socket and medium extension. just wants to strip. and that top nut, the open end 15mm wrench slips and i cannot get a nice twist due to room (and the brake lines are in the way).
am i missing something? thanks for any suggestions.
-b24
bluetwofour is offline
Old 08-30-2014, 07:45 PM
  #69
Grizzly old man's Avatar
dan
There are two bushings in the steering rack where it bolts to the frame, these might be what your parts man was talking about.
WoW! I did not realize how old your post was. Man am I on top of things or what?
Grizzly old man is offline
Old 08-30-2014, 09:42 PM
  #70
-b24
Yes you are missing something. Use the search box to find a few more threads about getting those things out. The "book" says to drop the cradle a couple of inches, but necessity is the motha of invention.
If it's not in this thread it's in one of the other 10 on the subject.
donbrew is offline
andyb
02-26-2015 06:55 AM
grugan74
37
10-12-2013 02:08 PM
BZERKED
12-28-2012 01:25 AM
Sneezy
55
09-17-2010 11:25 AM
Quick Reply: Front Sway bar bushings
