FYI on the Brembo's for the upgrade guys
I just installed the Brembo calipers on my SS, and using the stock brake hoses I find them stretched really tight at full turn. The problem is not the slightly larger diameter rotor, but that the Brembo caliper hose mounting point is about 1.75" closer to the centerline of the rotor. I recommend the longer Brembo spec hoses for safety.
The proper Brembo spec brake line is 1.5" longer, with a 1.5" longer "insulator" on it. The longer line is not near as stretched tight at full turn. GM pn 25954272, about $25 each, and come with new banjo nut and copper washers.
bpb355
16
Apr 20, 2014 10:53 PM
