FYI on the Brembo's for the upgrade guys
Old Sep 15, 2013 | 08:15 PM
Pudmunkie's Avatar
Interesting! I just replaced my brakes and wish I had seen this before!
Where are you guys sourcing lines, rotors and pads?? I may still run some of these down...
Old Sep 16, 2013 | 07:39 PM
lafinests213's Avatar
so i got the brembos calipers,rotors,and pads, what else do i need for the install? Can i still use my original brake lines.
Old Sep 16, 2013 | 09:45 PM
Yes, you can.....
Old Oct 8, 2013 | 08:20 AM
paperboy72's Avatar
late to this thread, but I was ordering my calipers as well and was wondering...someone in this thread mentioned spacers. Do we need wheel spacers on an SS when upgrading to the brembo's?
Old Oct 8, 2013 | 04:20 PM
Depends on your wheels.
Old Nov 10, 2013 | 03:59 PM
  #26
LT1GMC's Avatar
I just installed the Brembo calipers on my SS, and using the stock brake hoses I find them stretched really tight at full turn. The problem is not the slightly larger diameter rotor, but that the Brembo caliper hose mounting point is about 1.75" closer to the centerline of the rotor. I recommend the longer Brembo spec hoses for safety.
Old Dec 7, 2013 | 08:59 PM
  #27
LT1GMC's Avatar
The proper Brembo spec brake line is 1.5" longer, with a 1.5" longer "insulator" on it. The longer line is not near as stretched tight at full turn. GM pn 25954272, about $25 each, and come with new banjo nut and copper washers.
bpb355
16
Apr 20, 2014 10:53 PM
AJL08SS
Dec 16, 2013 03:11 PM
RobSSTurbo
Tires & Wheels
Apr 10, 2012 01:51 PM
RobSSTurbo
Racing Discussion
Apr 5, 2012 07:49 AM
coreycooper
21
Dec 18, 2010 11:39 AM
