Heavy Jobs With A Lowered HHR?
Old Apr 15, 2008 | 10:37 PM
courthousedeb's Avatar
Here's a thread that might interest you.
https://www.chevyhhr.net/forums/general-hhr-4/what-biggest-thing-you-hauled-your-hhr-1394/
Old Apr 15, 2008 | 10:42 PM
Originally Posted by The Lowest Law
so it's best to just stick with 17's and 3rd gen GLs?
I'm just SO very worried about dragging and rubbing when I load up my HHR!
3rd gen GLs should be the leveling set......rear only. Last month, I compared Dory to Nemo (Karen's ride w/ the levelers) and the back of Nemo actually sat lower than Dory. These may not be the way to go due to load making the back end sag more and takes that much more off the front wheels, making for some real light steering.
Old Apr 16, 2008 | 12:33 AM
xzombiex66's Avatar
I would go for the Eibach pro kit that what i did. plenty of spring rate to haul your PAs an such.
Old Apr 16, 2008 | 02:48 PM
Jay Budget's Avatar
I have the GL's a guy a I work with has the Pro Kit on his 07... If I had to due it again I would go Pro Kit - Such a better ride!!!!
Old Apr 16, 2008 | 09:39 PM
The Lowest Law's Avatar
better than stock?
Old Apr 16, 2008 | 10:53 PM
xzombiex66's Avatar
better than stock?
I think so
Old Apr 17, 2008 | 06:10 AM
consider me SOLD!
... now to find the money...
Old Apr 17, 2008 | 09:27 AM
ZTony8's Avatar
Did you change your shocks and struts to shorter stroke versions or stay with the factory pieces when you installed the lowering kit?If stock pieces,do they now bottom?
Old Apr 17, 2008 | 11:53 AM
Jay Budget's Avatar
The stock stuff does not bottom out. You dont need to do anything else other than cut your bump stops a small bit. The ride is better than stock. Springs will make the HHR come alive, gets away from all the mushy slugish feelings and adds some amount of confidence and handling to the car, not to mention alot of attitude Warning, once you get the springs, then you will want a sway bar, and then a ________, then a ________, you get the point, its very habbit forming....
Old Apr 17, 2008 | 10:34 PM
wow... i feel dumb... but... what are sway bars?
